My bike is surging / jolting / hesitant
Old Dec 9, 2021 | 07:50 PM
@Drew2785 Do you have an F3? Why are you trying to bypass the Air Vent Solenoid Valve? That is what helps ensure the carburetors perform optimally between slow speeds and higher speeds when it has to deal with the ram air effect. The Air Vent Solenoid Valve controls the pressure of the air in the airspace in the upper half of the float bowls. The light blue shows the air path below 12mph, and the orange is for above. The purple is the path it takes to get into the carburetor bodies.
In this picture, item #4 is a hole in the upper part of the Carburetor Body (the carburetors are upside-down in this picture). The Air Vent Solenoid Valve controls where the air is coming from. Below 12mph, the air comes from little "Deer Whistle" looking intakes right below the headlight. Above 12mph, the air is supplied from the main air intake duct which is being pressurized by the movement of the motorcycle as it moves forward.
Item #6 in the image below is what the Air Vent Solenoid Valve is supplying. The is one of the T fittings between each of the 2 carburetors. Between 1 and 2 as well as 3 and 4.
Old Dec 10, 2021 | 03:11 AM
Drew2785's Avatar
Default Thank you
Thank you very much for the help I have had the fairings taken off and the bike would jump round like a kangaroo when I try and open it up in high revs then had the air solenoid bypassed now it floods at low end and a beast at high end
problem I had was I don't have the origonal speedo fitted all fairings obviously have been taken off so at first bike was jolting me at high revs them bypassed the air solenoid now its fine at high revs but flooding at low revs
Old Dec 10, 2021 | 07:33 AM
So, you bypassed the Air Vent Solenoid Valve. How did you accomplish that? It has 3 hoses on it. Are any of them connected still? I suspect the Yellow line is connected, and at low speed, it is providing too much air.
Old Dec 10, 2021 | 05:10 PM
Drew2785's Avatar
HI thank u very much for the reply it has been set as per the picture but its the opposite issue now its taking on to much fuel and flooding the solenoid has been removed and the gape created joined I belive. The original problem when it was all set up as standard was at high revs it was taking in to much air now I have the problem of it flooding but runs great if you absolutely smash the revs the issue I think starts at the fact I have changed the speedo from the origonal
Old Dec 10, 2021 | 05:53 PM
Yes, the Speedometer sends a signal to activate the Air Vent Solenoid Valve via a Pink wire at 12mph. Did you start another thread? Take some photo's so we can see what you have.
Old May 9, 2023 | 10:12 AM
TwoganBrady2023's Avatar
Default Headlight Wiring
Originally Posted by bmxr123
So i have been building this 96 cbr600f3 streetfighter..She is a bad beast..But after I took the guages off and mounted an old school headlight, the bike surges sporatically. When i pulled the gauges i had to chop all the plugs that go into them in order to fit the harness into the headlight..I didn't really tape off all of the wire ends either. Is it possible that one of them could be grounding out? I just ran through the carbs, checked for vacuum leaks, checked fuel pump, changed the spark plugs, changed the fuel filter, so I know it has to be electrical. This would make sense because when it comes to wiring i have NO IDEA what im doing. My question is this: What should i check for in the wiring on the harness? Should i tape off all of these wire ends that i chopped? Thanks in advance for any advice!
I figured i would post a pic of the f3 im doing..I did the cbr600rr tail conversion myself..As long as you have a welder and some time its an awesome beginner's fabrication project!
Attachment 40739
Howdy i am looking to find out how you wired up ur headlight as i’m looking to do the same it not similar one
F3NGS
Jun 26, 2012 08:11 AM
CalKirley
Aug 19, 2011 11:22 PM
900rrSTUD
Oct 6, 2008 05:15 PM
Burly
Sep 22, 2007 11:01 PM
zeppelin2112
Jan 25, 2007 12:33 PM
