MOSFET or shunt type regulator/rectifier
Old 05-28-2010, 12:14 PM
KRUSHER F3's Avatar
Default MOSFET or shunt type regulator/rectifier
I've done some searches and reading on regulator/rectifiers and have seen alot of positive opinions on a newer MOSFET type regulator over the stock shunt type. I've also read the MOSFETs have a hesitation on start up which won't put an immediate load on your electrical system, which is good. The MOSFETs run cooler and work better BUT now the question: I've seen one from a Kawasaki Ninja 600 and Kawasaki ZX10 mentioned, what all bikes and years uses this MOSFET type regulator? Will the regulator from a bigger bike like a R1, ZX14, 'Busa, etc. work on a 600F3 or is the output about the same?
Old 09-14-2010, 10:03 AM
thedudeman's Avatar
I know this is quite a late response. Dunno if you found your answer, but any mosfet type will work. Since all modern vehicles run on 12V, the output of all R/Rs is designed to charge a 12V system (about 14V). I ahve a ZX-10 unit. Works great.
VERY USEFUL HINT: You can tell a shunt type vs. mosfet type by the part number. Shunt (SCR) types will have the part number start with SH, mosfet types will start with FH.
I think that about 100% of R/Rs made for bikes are made by the same company, Shindengen. So the part # scheming will be the same.
Old 09-14-2010, 12:35 PM
billetproof97's Avatar
Are these plug in play? or do you need a new clip for it as well?
Old 09-14-2010, 12:42 PM
thedudeman's Avatar
No. Not plug and play. There are sources that sell the correct connectors, but I just popped the wires (with spade connectors) out of the stock plastic connector and individually hooked them up to the ZX10 R/R.
http://s2.photobucket.com/albums/y10...t=DSCN1648.jpg
http://s2.photobucket.com/albums/y10...t=DSCN1650.jpg
Old 09-14-2010, 01:04 PM
That looks doable. and it doesnt looked "hacked" so to speak. I was just going to get a replacement OEM one, but these stock ones do not seem to cut it.(not trying to jack the thread) but my bike isnt starting at all, i put a different battery on it (from my other honda cb750) and my battery was fully charged, i turned it key on 750 and light and all work on it. i put it on the cbr and nothing turned on, all i could do was turn my alarm off and on, on the cbr. so i threw my battery charger on it think i could jump it that way and still nothing, but i did notice the battery was being drained, it was fully charged, and when i put it on the cbr it went down to the yellow light. so im hoping its the Rectifer. I checked all the fuses too. they are good. OEM honda recifiers are the bastards child of the charging system *excuse the french*
Brandon
Old 09-14-2010, 07:43 PM
KRUSHER F3's Avatar
I don't need one anymore, I got rid of the bike back in June but thanks for the info anyway.
Old 06-16-2011, 02:18 PM
JagerBombAFJ's Avatar
So I can't seem to find a thread specific as to which exact units will work. Is there one I am missing? I want to replace my R/R on my F3. I have an aftermarket one, but it's still a piece of crap. Pretty sure it's fried, puts out ~20v around 5k.
Old 06-16-2011, 02:36 PM
Monkeh's Avatar
Anything over 15v will kill your battery. I fitted a electrex reg/rec its working great and hardly gets warm. ive heard good things about tourmax reg/recs too. As already stated any reg/rec for a 12v system will work its just a matter of cutting off the connectors and fitting the ones off your old one. If you do decide on a 2nd hand one id go with 2006+
Old 06-21-2011, 11:00 PM
ANy thoughts on the made in china ones that are around $50 on fleabay? I am somewhat wary to get a used one, and it looks like prices may be around the same or more for a used factory one.
Old 06-22-2011, 03:57 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
picked up the gixxer one for 50 bucks.
for what it offers and how stable it is for our bikes, id recommend it
Quick Reply: MOSFET or shunt type regulator/rectifier
