loss of power - top of 4th & >8k in 5th
i had the coils tested at a motor sports dealer, and their good. i tried bypassing the fuel pump and routing the gas line straight to the carbs, and there is no difference in performance. only thing is i don't know if theres no difference because the fuel pump is bad, or because the fuel pump is only needed when there is a low gas level inside the tank. i'll run it with a low gas level to compare performance and post in awhile. still trying to figure this out
ive noticed that if i push the rpms anywhere past the point where it starts to run funny, i have to let the rpms fall a couple thousand before it starts to run smooth again. like it will run great anywhere below circa 7 of 8k but if i go over 7 or 8k it will give me herky jerky and ill have to let the rpms fall to like circa 5k before it evens out, and i can bring it back up to 6 or 7k no problem. somebody suggested a scorched cylinder wall to my father......
well i got a leak-down tester from aircraftspruce.com. im going to do a leak-down test, and a friend is letting me borrow one of those gadgets that has a camera on the end of a flexible shaft that hooks up to a screen display so i can look around inside the cylinders. ill post if i find anything ineresting.
