Let the mods begin
thats great wisco, by the way before you take your chain off make sure you loosen the front sprocket, i actually just did that ordered a new chain and sprockets, but i wasnt thinking when i did mine, i took the chain off then had to put the chain partially back on to even get my front sprocket loose, and also when you change your rear sprocket put a washer/ something thick in between your pads on the rear caliper to keep it extended that way you dont have to redo your rear caliper
