Jet Kits Worth It?
Old Mar 25, 2008 | 01:06 PM
F3Rider's Avatar
Default Jet Kits Worth It?
Has anyone bought a jet-kit for their F3? Just wanted to know if it was worth the money...and how much performance did uactually get out of it?
.....Easy to install?
-Thanks everyone
Old Mar 25, 2008 | 01:52 PM
Donohu40's Avatar
Default RE: Jet Kits Worth It?
It's worth it but definitly not something you want to install yourself. Unless you own a dyno and stuff. I'd definitly take it to a good shop with a dyno so they can tune it on the dyno. You can make your bike slower if its not tuned right.
Old Mar 25, 2008 | 02:11 PM
krayton's Avatar
ORIGINAL: Donohu40
how do you tune the jet kits? i was reading the jet kit installs, and you just select what setup you have and put that setup in
Old Mar 25, 2008 | 04:05 PM
kwong2001's Avatar
Jet kits aren't that hard to install, just takes time to tear the bike down to pull the carbs out. Only thing that might suck is if you have to do any type of drilling because if you screw up, then you need a whole new set of carbs.
The tuning isn't that hard, but it takes time and there's a lot of trial and error involved. Unfortunately, each change in setting made, you gotta tear the bike apart to get to the carbs to make the changes, put the bike back together, ride the bike to test the settings, then if more changes need to be made, you have to repeat the process. My Factory Pro jet kit came with a pretty good tuning guide which helped out a BUNCH.
Personally I wouldn't bother paying the extra money to have it dyno tuned unless the shop has an eddy current dyno. If it's anything less, have it tuned the way you want it, then stick it on the dyno just to check the air/fuel ratio.
ORIGINAL: krayton
On a jet kit, the tuning is basically picking the best main jets (high end), then you change the settings for the needles (midrange), then the settings on the fuel screws(low end/idle), so there's essentially three settings you'd play with. Each setting also overlap to some degree.
Old Mar 25, 2008 | 06:15 PM
F3Rider's Avatar
hmm....maybe i wont mess around with it then. Sounds like quite the hassle....but it would be nice to do it, damn!!
Old Mar 25, 2008 | 06:34 PM
pointman's Avatar
ORIGINAL: F3Rider
i hear yah , i wanted to do get one on my bike but ended up scrapping that thought , to much to do . if i need more speed get more ccs and im not ready for that just yet .
Old Mar 25, 2008 | 08:32 PM
Donohu40's Avatar
Yea, sorry i didn't elaborate. You dont tune a jet kit, you just use a dyno and other tools like air/fuel stuff and such. I don't want to turn you off from doin it, just wanna make sure you get it done right. Other than exhaust its the only easy way to go faster so i'd say its definitly worth it.
Old Mar 26, 2008 | 05:33 AM
pointman's Avatar
ORIGINAL: Donohu40
do you have a full exhaust system or slip on ?
Old Mar 26, 2008 | 11:24 AM
Syphen's Avatar
I put a Hindle slip on pipe onto my F2, with a "custom" aka homemade midpipe and such onto my F2, then I put a K&N airfilter onto the bike. When I first bought the bike it dyno'd at 82hp. After Dynojet Stage1 kit, pipe and K&N, it dynoed at 89hp. (Tuning was done on dyno at shop that installed jet kit.)
I did not really feel a difference in the total power, but one thing that I could for SURE tell is that acceleration felt harder and much more linear and smooth. It felt like a brand new bike.
Old Mar 26, 2008 | 02:46 PM
pointman's Avatar
ORIGINAL: Syphen
how much did you pay to have it tuned ?
