Instrument panel
RE: Instrument panel
looks homemade to me, should not be to difficult to build, just pick up a tach you like and a temp gauge youlike, and mount them to 1/4" plastic board then paint, next make a couple brackets to attach the new cluster to the bikes mount,after that you just need to dig up the schematics for your gauges (if you want to hook to the factory wires) or you can just run a new wire to the temp sender, and a new wire to neg side of the coil then your power, ground and light wire if you want it to light up. best of luck
