indicator relay location cbr600fv 1997 ?
Old Jul 16, 2012 | 03:01 PM
loza's Avatar
New Member
Question indicator relay location cbr600fv 1997 ?
Hi all can anyone tell me where the indicator relay is on a cbr 600fv 1997 as my front left indicator wont flash but the back one flashes very fast i have checked the bulbs there all ok and both right ones are working fine . any other ideas welcome. Thanks.
Old Jul 16, 2012 | 05:58 PM
MadHattr059's Avatar
Up behind the guages, on the right side. It's a black box about 1" square.
Ern
Old Jul 16, 2012 | 06:37 PM
SoulReaver's Avatar
wire lose maybe? it flashes fast when you have a bulb that is no good. since you checked them and they are all fine then i would think wires maybe lose or off. the flasher works because they are flashing. check the wires bro. good luck and let us know
Old Jul 16, 2012 | 06:56 PM
I would replace the front one, whether it "looks good' or not. Sometimes the break
is down in the base, where it's not visible. If that doesn't work, check the socket,
to see if it's getting any current. If not, start tracing back from that wire
(not the green one, that's ground, although you should do a continuity check on it
(to the chassis/engine), to assure it is a good ground) and see where the interupt is.
Good luck, Ern
gissmo50
Feb 15, 2010 08:56 PM
EPNF4i
Feb 5, 2007 10:02 PM
Reefa
Jan 29, 2007 09:14 AM
redliner25
Aug 25, 2006 04:33 PM
stang930
Jul 6, 2006 12:42 AM
