i need help to please!!!
ok i have been passed now for two weeks woo hoo anyhow my 1996 cbr600ft keeps flooding so i have to keep taking the plugs out and cleaning them its now getting a little frustrating just wondered if anybody had any ideas what the problem may be as i ride it two or three times then its of the road until i can get the plugs out please please please help i have only been doing short journeys do we think this may be the problem????? do we think the carbs may need balancing if so any body from the midlands
where i can get this done
carl
carl
it could be your carbs like you said, but a few things to check. make sure your air filter is not too dirty.A dirty filter will make the bike run rich.
A low battery will also make the bike flood out. This happens when the bike doesnt turn over fast enough to start, but still dumps gas into the cylinders. Even a slightly slower turnover of the engine can have this effect. these engines need to spin relatively fast in order to start properly.
If your plugs have fouled once, its a sure bet they will again and again. these plugs are very sensitive and they never really fire right after a good fouling. I would suggest getting a new set of plugs. Make sure they are NGK R series. Champion plugs are horrible and foul out.
I would guess on dirty carbs vs needing to sync the carbs. A dirty air screw or even a sticky choke will cause these problems.
