I KEEP MISSING 2ND GEAR!!!!!
Old 09-05-2008 | 09:19 PM
lonewolfcbr's Avatar
Default RE: I KEEP MISSING 2ND GEAR!!!!!
Powershifting is with the throttle wide open....and banging gears...the clutch is also used in "powershifting", this shifting method is more or less blipping the throttle and applying pressure to the shift lever at the same time, but you have to apply a good deal of pressure or you will false neutral or grind gears,its much easier on a bike than it is in a manual car/truck. http://www.ehow.com/how_2000670_clutchless-shift.html pretty much a good explanation, can be applied to a bike
Old 09-05-2008 | 09:28 PM
lakaiguy's Avatar
WOW ok I lowered the shift lever a hair or two and its at least 75% better
that lever is key to good shifting (and unbent shift forks)
whats the least amount of threads youshould have in the end links?
im pretty close to the end, but I want to lenthen it just a hair more
Old 09-06-2008 | 01:14 AM
Sproutf3's Avatar
Registered Users
Change your oil if its shifting weird...it wont make a HUGE difference, but i alway's noticed a difference in the shifter after fresh oil
Old 09-06-2008 | 12:47 PM
soccer13pro2007's Avatar
how do you change the shifter position? is it that toothed piece with the clamp?
Old 09-06-2008 | 01:15 PM
lakaiguy's Avatar
no the part you're talking about is part 4 in this diagram
that has a set position for max torque
but the pedal, part 2 can be moved up and down for maximum leverage
which is very important for good shifts
its adjusted by backing out the two locknuts 16 and 20 and then lengthening or shortening the shaft 13
Trent Dog
07-09-2012 06:32 PM
patches_mcmatt
11-07-2010 11:10 AM
NYKnick1015
02-19-2010 11:19 PM
filthy1
02-19-2008 10:46 PM
Quick Reply: I KEEP MISSING 2ND GEAR!!!!!
