How to remove rust from gas tank?
Hello,
I bought my F3 after its been sitting without moving for years. As a result of that I have my gas tank rusted from inside. The bike runs ok, but after while its hard to start up and engine just stops when in idle. I cleaned the carbs, the pump and thefuel filter but the problem repeats again. Do you have any ideas how I can clean up my gas tank and remove all the dirt and rust from it? Is there any chemical stuff I could use safely.
Thx
Thx
RE: How to remove rust from gas tank?
I have some out in the shop, but can't remember the full name. Kreem is part of it. Yes, it is about $35 for the kit. I am not sure if you can buy it separately.
It is good stuff! If you use it, take your time and fully clean all the rust out with the supplied cleaner, then coat it many times with the sealer. Let it fully dry. Sounds like you are looking for the cheap way out, but this will never re-rust if done properly.
