How to Remove CArbon Fiber GAs tank PAds?
Some of the pads (Stickers) are coming of but it seems that the glue or sticky stuff is really strong. What would be the best way to take them off the tan so I can clean the surface area under there and get some fresh new carbon fiber tank pads?
Thanks
Thanks
WD-40 slowly peel a little bit of sticker,spray some WD-40, wait awhile then repeat.
if you feel confident enough that the sticker won't take the paint off, then peel it off, then just WD-40 the glue left behind, let sit for 15 or so minutes. then wipe clean, repeat if any glue remains. also you can use a hair drier to heat the stickersto aid in the removal process, best of luck to you
nothin worked for mine...so i resorted to sticker label remover, a razor blade, and luck. i didnt scratch it up too bad, and i had another tank pad to slap right back on
CJardine
How-To: Mechanical
18
Mar 16, 2013 05:23 AM
