How do I remove both wheels at the same time ?
Old Aug 13, 2007 | 07:39 AM
tvoburner's Avatar
Default How do I remove both wheels at the same time ?
Hi,
I have just bought a pair of new tyres and I was just wondering if somebody could please advise the
safest way to remove both wheels at the same time so that I can take them to the tyre fitter.
Any advice gratefully recieved
many thanks
Dave.
1995 cbr 600 F.
Old Aug 13, 2007 | 07:42 AM
madmike01uk's Avatar
Default RE: How do I remove both wheels at the same time ?
Paddock stands would be the safest way, other than that I think it will be tough.
Old Aug 13, 2007 | 08:07 AM
gixxereater's Avatar
+1..........track stands will be your best friends. Once you own a set you'll wonder why you didnt own them the whole time.
Old Aug 13, 2007 | 09:05 AM
MikeInCtown's Avatar
Set of stands makes things a snap. Up on rear first for me, then pop the front up.
Old Aug 13, 2007 | 09:12 AM
FoxRacin17's Avatar
yea, definately get the stands. well worth it.
Old Aug 13, 2007 | 10:45 AM
marc0011's Avatar
I use a chain hoist. I take six tie downs and loop them through various certain areas of the frame and then lift the bike till both wheels are off the ground. Makes life great for tearing down the bike and greasing up all the pivot points as well as for changing tires. If you use this, don't go too far back on the sub frame because it isn't meant to hold the weight of the bike. Use the neck and just above the engine because the frame is extremely rigid in these areas.
Old Aug 13, 2007 | 12:44 PM
Seems easier to use paddock stands to me, you would be less likely to damage anything. What grease do you use forthe pivot bolts? Is WD40 not better?
Old Aug 13, 2007 | 05:02 PM
Scrufdog's Avatar
stands are the easiest way to do it.
otherwise the strap method works fairly well if you have something overhead to strap to. Before I got stands I pulled all the fairings off, hooked the frame on either side near the motor then to a beam in the shed. For the rear I hooked straps near the seat mount and up to the beam.
Old Aug 13, 2007 | 05:15 PM
marc0011's Avatar
I don't recomend WD-40 because it is more of a cleaner than a grease. I disassemble the whole rear suspension from the rear shock to the swing arm. I clean out the old grease in the bearings (They are needle brearing) and then put in clean grease on the bearing of the pivot points in the rear suspension. The grease I use is Bel-Ray Waterproof Grease. A warning though, it isn't a high temp grease and it melts when applied to high temp components. I.E.the caliper pins on the brakes need to be greased and I use a high temp grease for them.
Old Aug 14, 2007 | 08:17 AM
redzintimidator's Avatar
Ive gotta weldmyself up some of these. I have the measurements and the materials, just need time!! and oh yea, a bike might help...lol good thing thats coming...
