how do I put this together?? carbs issue
Old 12-02-2010 | 01:26 PM
elivancho's Avatar
Default how do I put this together?? carbs issue
Hi guys..everything went well with cleaning the carbs on my 1996 f3....the only question and problem I have is that I forgot (not explained in manual) how to deal with the thrust spring..I know where it goes but is when you put carbs 1 and 2, and 3 and 4..look at the pics...it is just the stay set..and sync screw spring.....to move the throttle cable..u know..
Help me with this...I just want to finish the carbs......
here some poor quality pics..but you can see what I mean..
thank you,
Ivan
Attached Thumbnails how do I put this together?? carbs issue-1202001116.jpg   how do I put this together?? carbs issue-1202001117.jpg   how do I put this together?? carbs issue-1202001118.jpg
Old 12-02-2010 | 05:31 PM
Are you looking for a photo of how it looks or how to get the 2 to go back together ?
Old 12-02-2010 | 08:35 PM
elivancho's Avatar
thank you...I do have the pics and Know how to put it back and where everything goes.....it is when you put them together( 1&2(3&4) my problem based on ur pics...is the two big springs underneath the heater joint pipes...just do not the name of it...they move in circule with the throttle cable.....not sure if I made myself clear......thank you!!
Old 12-02-2010 | 09:21 PM
TooBroke0029's Avatar
are you taking about reattaching the throttle cable? im confused by the question?
Old 12-02-2010 | 10:31 PM
elivancho's Avatar
so am I....I do not know how to ask....please if u look at my pics u maybe able to figure out what I mean..when you assemble the carbs..1&2,3&4..the throttle cable goes to its place..then next carb has other round metal piece with the thrust spring..the question is how those two pieces engage to each other?..thank you..maybe this pic can help..
Old 12-02-2010 | 10:47 PM
elivancho's Avatar
thank you for your pic. I can use it to show you my problem.....I made green marks on it!!
Old 12-02-2010 | 10:53 PM
elivancho's Avatar
I used your pic to point out my problem with green marks...I hope you can understand me...thank you for ur answer..Ivan
Old 12-02-2010 | 11:12 PM
I'm in the process of cleaning mine as well. I hope these photos help. The large spring just sits inbetween. I didn't put that in the photo, but should be easy to get in.
File Type: jpg
Old 12-03-2010 | 12:23 AM
elivancho's Avatar
Default Fantastic help..........thanks a lot...!!
This is what I was talking about...........Great now I can do it!!!!!!!
Well having your help is better than taking the bike to the shop....When u go to the shop you get the bike fixed,yes but I can not learn!! knowledge is power!!!!!! thanks.. Ivan from L.A
Old 12-03-2010 | 11:09 PM
Glad I was able to help. I was able to get a nice shot of the Slow Jet showing the really small hole in it.
Quick Reply: how do I put this together?? carbs issue
