How bad is it
Old Aug 25, 2012 | 10:48 PM
djkain's Avatar
Default How bad is it
Found out my Head gasket went and 2nd gear was slipping. When I dropped the engine and split it this is what I saw. Do you think just a good scrubbing with some carb cleaner will take care of the engine and I already have the replacement Gear dog.
Old Aug 26, 2012 | 08:11 AM
74demon's Avatar
Hard to tell by the pic, but that piston looks damaged. What does the cylinder wall look like? Measure the bore good and check for scoring. It may be time for a motor. Did you happen to check compression before you took it apart?
Old Aug 26, 2012 | 10:12 AM
Bacarra's Avatar
Registered Users
Default Nope no compression test
We knew we had to find the reason for oil in the coolant so we just decided it would be better to rebuild it. Thanks for the tips on checking bore and stuff on it. We plan to almost rebuild the total engine.
Old Aug 27, 2012 | 08:49 AM
djkain's Avatar
Don't remember any scuffs I know the bike had full power before braking it down. I was putting the back fairings on when I noticed the Coolant tank was darker then it should and noticed there was oil in it. From checking on the forums there were 2 places it could be the oil cooler or head gasket well the oil cooler had brand new "O"-rings and looked good which ment the head gasket.
Old Aug 28, 2012 | 01:21 AM
4ws.ba4 F3's Avatar
Was there coolant inside the motor oil? Or just oil in the coolant? Not trying to be insulting, just wondering if it could have been the oil cooler, but hell, now thinking about it, if you have second gear problems, why not rip it apart and fix it all anyway. Good luck getting all together, hope it goes smooth.
Old Aug 28, 2012 | 03:29 PM
djkain's Avatar
All the gaskets and o-rings in the oil cooler were good. Didn't look like there was any coolant in the oil.
Old Aug 29, 2012 | 07:22 AM
kjohnson's Avatar
Use an OEM gasket kit for your rebuild.Don't skimp,unless you want to do this again.
Old Aug 29, 2012 | 08:03 AM
djkain's Avatar
we already have the part numbers for the OEM upper and lower rebuild kits. something like 350 bucks
Old Sep 4, 2012 | 08:47 PM
djkain's Avatar
ok got the pistons cleaned up need more work on the valves. There were no scuffs in the piston chambers they look clean a couple of the valves look pretty beat up and the stamp on them cannot be seen do you think they need to be replaced?
Old Sep 12, 2012 | 06:31 PM
partsguy's Avatar
Make sure the head isn't warped.May be a good time to have the seats cut too.
