Help me!!!!
Help me!!!!
I'm getting so frustrated I'm half tempted to sell it. It's causing me lots of heartache and stress not to mention time and money. My 96 f3 was acting like it was running out of gas and leaving me stranded far from home. I disconnected the fuel pump output and it wasn't pumping gas. so I replaced the fuel pump. Still no luck. Checked the fuel filter and it was not allowing fuel through so I just flat out took it out. Now I tested the new pump after that and it pumps gas. The bike started up but was running really rough. I tried to give it gas and it just killed it. Let it sit a couple days and started it up this morning and let it idle for about 10 minutes and sounded fine. Took it out on a short ride and about a mile from home it acted like it ran out of fuel. Just before it died it sounded really rough again. So yes I pushed it all the way home. Good workout by the way. Does it sound like something as simple as dirty air filter (which it is, just haven't replaced it yet) and dirty carbs? I don't know. Gonna try to take apart the carbs today and spray some cleaner in it. And if I get around to it gonna change the plugs today whether they need it or not. I figured while I have the airbox off I'll change the plugs.
ok, its not the air filter or it would affect it from the start. i dont have an f3 my self but since no other answers here goes. yes clean the carbs. while they're off drain your tank. it sounds to me like something is in your fuel that is settling and then clogging back up when you ride be it dirt or water. also if you have petcocks (1 or 2) check it or them. ive had one bike that would act up because it was fault. once the tank is empty shake the h ell out of it to see if you can hear anything in it that you cant see with a light. my bet is that you have trash in your carbs though. if the filter was clogged completly chances are some crap pushed through. good luck with it.
ok, its not the air filter or it would affect it from the start. i dont have an f3 my self but since no other answers here goes. yes clean the carbs. while they're off drain your tank. it sounds to me like something is in your fuel that is settling and then clogging back up when you ride be it dirt or water. also if you have petcocks (1 or 2) check it or them. ive had one bike that would act up because it was fault. once the tank is empty shake the h ell out of it to see if you can hear anything in it that you cant see with a light. my bet is that you have trash in your carbs though. if the filter was clogged completely chances are some crap pushed through. good luck with it.
