Help installing a manual CCT
Actually you have to use a special tool to compress the tensioner before removing and installing it, so it's not just two bolts.
Here you go.
Here you go.
Here you go.
Here you go.
take old one out, put new one in.. hand tighten the thumbwheel and use your best judgement of how tight you think a cam chain should be. too loose = loud clanking + potential disaster. too tight = quiet, but you can imagine how much stress its putting on the cams. start it up, and listen to it. cut it off and make adjustments accordingly.
Trips
07-15-2009 10:56 AM
aclarkgto
02-15-2006 02:41 AM
