Help Fitting Alternator Cover
Old Mar 24, 2014 | 01:06 PM
mashava's Avatar
Default Help Fitting Alternator Cover
Fitting a new alternator cover the reduction gear is out of place so the dowel won't align back with it but I can't move it by hand
needs to be moved forward (left if you're facing the bike) but don't know how to please help me if you can
HONDA CBR 600F (1996)
Please See Pictures I posted below hope they work i'm new here
Attached Thumbnails Help Fitting Alternator Cover-148855_10152118156646026_382184519_n.jpg   Help Fitting Alternator Cover-1536636_10152118156051026_738741564_n.jpg   Help Fitting Alternator Cover-10007009_10152118156376026_563271283_n.jpg
Old Mar 24, 2014 | 04:02 PM
PossibleOne's Avatar
Welcome Crew Technician
Hmm, on my F4i, I can take that little cog out. I am pretty sure you have to put the pin in it first then realign if that makes sense. Took a little bit of work to get it back to the right place.
-Poss
Old Mar 24, 2014 | 04:37 PM
mashava's Avatar
thanks but i can't take that gear reduction gear out (cog whatever u wanna call it) need to find a way to move it thought i would have got more replies than this by now thanks for your help though man the pin needs to stick out a little bit to go into the alternator cover too, but the problem i have now with it having moved down is that it now goes all the way into where the shaft is because that bit as a lot deeper than where it as acutally meant to be...
Old Mar 24, 2014 | 05:23 PM
Gear turn? What do you mean you cant move it? You are going to have to move it to get it where it needs to be. Grab a hold of it and try to rotate and move, it will come free and you can then put it back the way the manual describes it.
Old Mar 25, 2014 | 04:19 PM
mashava's Avatar
do i need a specific tool to do this?
cringer
Nov 8, 2010 11:54 AM
Gotpepsi
Apr 26, 2010 04:54 PM
wentsCBR
Aug 25, 2008 03:48 AM
dizzie56
Mar 28, 2007 10:07 AM
