help it dies all the time
Old Apr 4, 2005 | 01:01 AM
transambird_2000's Avatar
Default help it dies all the time
my 96 f3 has a bad problem with dieing if you dog it under 6k rpms. It runs fine if you keep the rpms up, but it is a pain in the butt. I gave it to my girlfriend to ride and she doesn't ride it as aggressive as i did so it is causing a problem. Which means i end up on the old f3 and give here my 05 rr to cruise on. No fun. anybody got any suggestions
Old Apr 4, 2005 | 02:14 AM
sirlimpzalot's Avatar
Default RE: help it dies all the time
This gets covered alot!!
here we go...It sounds like dirty carbs, somthing is plugging your idle jet it sounds...or here is a stupid question?? When does it die??if it is only after it drops down near idle then what I said is probally true, or it could be a fuel delivery problem ( such as an old in line fuel filter if you have one installed)
If it has sat for a long time it is in need of a carb cleaning ( remove the carbs and pull the float bowls and remove and clean/replace the jets if plugged) If you have a service manual this is covered in that book
Phillyf4i
Dec 1, 2008 09:42 PM
DJ SLYKE
Jun 1, 2006 11:45 PM
andyjenks
Mar 17, 2006 01:00 PM
transambird_2000
Apr 4, 2005 02:11 AM
