help with clutch adjuster
Today on my way to work I noticed that the lock nut on the clutch adjuster was spinning around freely. When I had a chance to stop I noticed that the adjuster was turned out away from the clutch perch almost all the way (to the point where it would wiggle if touched). This gave the locknut about a 1/2 inch to slide back and forth in the space between the perch and the adjuster. My question is, should the adjuster be screwed in closest to the perch, or unscrewed out towards the windshield?
<--- from the service manual
