heater hose to carbs
I took the carbs off for a motor swap because of a broken journal on the block from the starter. I have the coolant line running from the thermostat valve that is bolted to the same bracket as the starter. I need to know where this coolant line goes into the carbs. I already have the carbs on the motor with the motor mounted in the bike. Carbs arent screwed down but they are on the motor. The throttle cables, choke cable and clutch cable are binding, how would i go about fixing this? Thanks in advanced.
Thanks a lot. I have to pull the carbs of again to retighten the starter bolts. Plus I want to put the isolator bands on the carbs instead of the intake because putting the carbs on with those on the motor is easier than on the carbs already. Ill figure out the heater hose. I should have taken it off of the valve instead of the carbs. Oh well, Ill figure it out. Thanks though.
