Headlight stays on high beam
Old Mar 29, 2013 | 10:37 AM
cbr_rob's Avatar
Default Headlight stays on high beam
Hi,
I've had a problem with the headlight ever since I bought the bike: the low / high beam switch doesn't seem to work at all and as a result it's staying on high beam the entire time. Bulbs are fine.
I've taken a look at the light switch assy, slightly sanded the connections a bit but this doesn't seem to be making any difference.
Am I right for suspecting the light switch assy? Or is there anything else that anyone would recommend?
Any tips much appreciated!
Old Mar 31, 2013 | 09:35 PM
ryantgustafson's Avatar
It sounds like the switch. Go at it with a multi meter and that will tell you whether it is working or not. Easy way to diagnose it. God luck!
Old Apr 1, 2013 | 10:03 AM
cbr_rob's Avatar
True. I guess I was hoping there was a quick (and cheap) fix that wouldn't require replacing the entire assy. No such luck I guess.
Santos4288
Dec 21, 2011 07:24 AM
zjwilliams
Jul 18, 2010 01:20 AM
Oldest Sage
The Hurricane Saloon
Jun 19, 2009 09:18 AM
cut_cutta
Feb 18, 2009 02:49 PM
motonewbie
Sep 9, 2008 09:33 PM
