headlight question?
Old Apr 17, 2009 | 12:52 AM
OffRoadYota's Avatar
Default headlight question?
when i turn the high beams on i get a dark spot in the middle of the road, but the light is still bright around the sides, and the low beam works perfectly, would just the high beam be burnt out?
and what kind of bulb do i need to replace it with?
Old Apr 17, 2009 | 02:30 PM
willduce's Avatar
when high beams go out, you dont have any high beams,. only low beams. i think f'3 take an h4 bulb. you can get them at auto zone and such
Old Apr 17, 2009 | 06:45 PM
As WillDuce said, when you turn on the high beams, if it's burnt out, you get nothing. Both high and low are not on at the same time. It's one or the other.
Old Apr 18, 2009 | 05:30 PM
thanks guys, i took some pictures of the way the light spreads on my way home tonight so i will upload the pictures tomorrow
Old Apr 19, 2009 | 07:19 PM
ok so i got the pictures of the high and low beam,the bike was dropped a coulple times by the previous owner and i just found this problem recently on my first night ride with the bike.
Attached Thumbnails headlight question?-hpim1236.jpg   headlight question?-hpim1237.jpg
Old Apr 19, 2009 | 09:58 PM
You can probably pick up an H4 bulb from an auto parts store for less than $20. It wouldn't hurt to check your existing one and make sure that it's been installed correctly. If you remove the lower inspection cover below the headlight ( it's black and only has 2 thumb tabs holding it on) you can reach up behind the headlight, unplug it, remove the black rubber cover, then unlatch and remove the bulb. Don't touch the surface of the bulb if you take it out. It may be that it's not seated correctly in the headlight housing. There is a spring loaded bail that's holding the bulb into the headlight.
Old Apr 20, 2009 | 10:24 PM
littlegags's Avatar
Has anyone put any after market bulbs in an F3. I have a 98 and the light just does not seem very bright. I just bought a replace ment H4 bulb and I also got some Headlight cover cleaner ( Like a polish ). I am going to try to clean it up and try a new bulb and see if that helps.
Old Apr 21, 2009 | 02:59 PM
willduce's Avatar
when i got my bulb i just got a higher output "white light" bulb. a few bucks more but much better lighing
Old Apr 21, 2009 | 03:56 PM
Endless's Avatar
Siggy Maker & All Round Good Guy
If it is alignment your are concerned with then there is two adjuster ***** located diagonally
on headlight assembly. You can adjust these manually while the bike is on if you can reach your arm in there.
Us F3 owners don't have the liberty of those newer bikes with the electronic on-dash light adjusters.
It looks like your lights are fine. You might just want to raise the circumference. The bright is supposed to be a little higher because it is designed to let you see further ahead and in a wider view. The void in the middle you see is actually the silhouette of the wire assembly in the bulb.
inkredibleg
Apr 9, 2008 09:45 PM
malibuken65
Apr 14, 2007 11:42 PM
fiveoh
Apr 1, 2007 09:06 PM
Tantric
Mar 20, 2007 01:41 PM
spidertron
Apr 29, 2006 02:43 PM
