headlight issue
Old Jul 28, 2012 | 03:03 PM
sjona2011's Avatar
Default headlight issue
so earlier this week i noticed that my headlight was not working, hi or low beam. i checked the fuses, all were good. made sure the connection to the bulb was good, it was. so i figured the bulb was burnt. didnt bother getting a new bulb cause i had an hid kit on order. the kit came in today, got it all installed correctly, plugged everything in, and nothing. double checked all the fuses. then i checked to see if i was even getting voltage at the plug, and im not, also noticed the hi beam light wouldnt come on.
just tried cleaning the hi/low beam switch.
dont really know where to go from here. anyone else have a similar issue or have an idea as to where i should look?
thanks.
Old Jul 28, 2012 | 03:19 PM
Take a look at this thread. No power to the headlights is common on Honda's.
https://cbrforum.com/forum/cbr-600f3...issues-126844/
Old Jul 28, 2012 | 04:48 PM
sjona2011's Avatar
you nailed it on the head, a lead broke loose on the starter switch, gonna solder it back up in a little bit.
Old Jul 28, 2012 | 09:49 PM
Espguitarist33's Avatar
Yeah, blue wire in the right handgrip right? My bike came with a piggybacked switch on the high beam wire and i thought I fixed that blue wire, well i got stranded 930 at night on a wooded road in a downpour with no light whatsoever. fix it really good or get a new handgrip. I taped the living crap out the inside of that grip just in case so it can't short out
Old Jul 29, 2012 | 12:30 AM
sjona2011's Avatar
i think it was the blue/black wire
and i soldered it up pretty good.
itsme71190
Jun 18, 2011 08:40 PM
AggieLawyer
Sep 17, 2009 10:37 AM
2005RX8
Sep 28, 2008 10:52 AM
vietladin
Jan 14, 2008 11:57 PM
cafrin100
Apr 30, 2007 01:05 PM
