header stud
Hi all, just a quick question-,when removing my downpipes,oops,sorry headers for you guys over the pond! 1 stud came out of the head with the nut(for the life of me i couldn't release the nut from the stud,so have ordered a new nut and a new threaded stud from honda)
my question is- do i use a locking compound on the exhaust stud that threads into the alloy head or not?
getting there with the full service,hopefully back on the road in a week------- or so!
ride safe and enjoy,
Ant.
Ant.
Yes, Honda manual recommends thread lock. When you replace the stud, use 2 nuts with a washer locked together to allow you to fully insert it.
Also, when tightening the downpipe plate start with the center stud then left/right.
Take 2-3 passes to ease the plate down evenly so it doesn't bind/bend the studs.
Ern
Ern
cheers guys,when doing the locking a washer between to nuts method to insert the stud fully,is there a torque required? maybe 8-10 Nm or so?
or just get the thread fully inserted,with no thread left showing into the head?
Ant.
Ant.
The manual calls for 20 nm on the flange nuts, when installing the down-pipes.
It doesn't mention stud replacement, so I wouldn't exceed 20 nm while installing the new studs either.
Ern
Ern
