gauge swap
Old Oct 3, 2008 | 12:50 PM
mikemcw's Avatar
Default gauge swap
Hey every one, I completed my F4I gauge swap but I have two extra wires from my bike side of the wires. I have a solid green and a solid pink wire left. Someone told me to ground them out butI wanted a second opinion. Should I just splice them together and then connect them to a ground? They said that the pink one was a regulator or low speed something. Would this not being hooked up cause my bike to run differently?
Old Oct 3, 2008 | 01:25 PM
Default RE: gauge swap
That Pink wire controls the Air Vent Relay. The relay is turned on and off depending on if the bike is moving above or below 12mph. I would think that if it's not functioning, then there are going to be performance issues either during high speed or low speed operations. If you ground that wire, the Air Vent Relay will be on all the time. It will turn off when the key is turned off since the supply voltage is controlled by the ignition switch. How well or not so well the bike performs afterword I don't know. Let us know what you find out.
Old Oct 4, 2008 | 03:31 PM
soccer13pro2007's Avatar
If you do a guage swap, can you wind the odometer to your previous amount of miles?
Old Oct 4, 2008 | 11:39 PM
bullit_70's Avatar
yes you can but you have to send them in. bluegauges.com does it.
Old Oct 5, 2008 | 08:25 AM
and about how much will a gauge swap cost? I need to do it on my bike. The trip meter doesnt work, the middle speedometer light is out so I cant see 45-85 at night, and either my thermostat gauge is broken or the actual part is messed up.
Old Oct 5, 2008 | 08:33 AM
mikemcw's Avatar
My swap cost me 53 dollars. I got the gauges dirt cheap for 50. The rest was for bolts and spacers. The only real cost is the gauges and how ever you are going to mount them.
Old Oct 5, 2008 | 10:36 AM
bullit_70's Avatar
ok here is the list
gauges = 112
temp sender = 25
Plexiglass = 1.53
nuts and bolts = 5
watching it start up for the first time = priceless
Old Oct 5, 2008 | 08:58 PM
mikemcw's Avatar
I still have to do the temp sender. Temp sender = winter project.
Old Oct 6, 2008 | 12:45 PM
mikemcw's Avatar
Ok I got my bike fixed. I connect the two extra wires toa ground and my bike runs great now. Now all I have to do is the temp sender and the speedohealer.
F3Rider
Sep 8, 2013 04:29 PM
bullit_70
Oct 17, 2008 02:32 AM
kgrahams1
May 11, 2007 11:07 PM
craigtheman
Apr 1, 2007 04:31 PM
Armstrong
Jun 8, 2006 08:31 PM
