gas cap dissembly
Old Apr 14, 2009 | 07:21 PM
89cane's Avatar
Default gas cap dissembly
does anyone know how to take apart the gas cap on these things. i want to powder coat mine but have to take it apart first. i need to be able to remove the lock and such.
thanks in advance for all the help
Old Apr 14, 2009 | 07:30 PM
I had to replace a lock set (ignition, gas cap and helmet) a few years ago on a 97 F3. I don't recall the gas cap lock being able to be taken apart. I thought it was riveted together. I could be wrong though as it was some time ago.
Old Apr 14, 2009 | 11:00 PM
89cane's Avatar
well thats troubling
Old Apr 15, 2009 | 02:22 AM
beasley600cbrf3's Avatar
I just went thru the same thing,I bought a tank with gas cap encluded..but no key.Pain in the ***.If you have the key.take the allen screws off on the outside ring,then use the key to open and remove it.If you don,t have the key...you can take your serial number from the bike to a honda dealer and you should be able to get the key.I tried once to just insert screw driver and turn to unlock it.I dont know why but..you would think that gas was 1.000 dollars a gallon.I was about a half an hour removing the lock from the gas cap{without damaging the tank}I'll still be buying a new cap..But I got her off though,It was tough a sucker! Good luck.
Old Apr 15, 2009 | 10:15 AM
89cane's Avatar
i can take it off. i want to take it apart dont know if i can but that is the hope
Old Apr 15, 2009 | 11:36 AM
I'll take another look at mine today..I'll let you know.
Old Apr 15, 2009 | 02:50 PM
marc0011's Avatar
Once the caps are removed from the tank, they can be disassembled. You'll pretty much tear the seal in it though. I had a cap that was damaged and I took it apart for $hits and giggles. You can take a flat head and separate the top half from the bottom half. Be careful of the tumblers though, they will fall out and are REALLY easy to lose. I think there was a small spring in there too that you'll need to be careful of.
Old Apr 15, 2009 | 03:53 PM
89cane's Avatar
cool i will have to try before two long
thanks again
