-   CBR 600F3 (https://cbrforum.com/forum/cbr-600f3-17/)
-   -   Is the Fuel pump relay the same as the Headlight relay? (https://cbrforum.com/forum/cbr-600f3-17/fuel-pump-relay-same-headlight-relay-146275/)
jag007 Apr 22, 2013 06:20 PM
Hello again,
This is my 2nd post - still trying to help my son fix his 96 CBR 600 F3.
I think he has a bad fuel pump (cut-off) Relay.
While stumbling around here I found a manual download.
So now we know where to look for the relay and wire colors etc.
But I've read here that the fuel and headlight relays are the same??
Can anyone confirm this please????
Also is there any aftermarket relay that works for the fuel cut off??
Thank you very much for your help
Regards,
jag007
CorruptFile Apr 22, 2013 07:26 PM
Doesn't look like it. By looking at the wiring diagram, the only connection between the fuel pump relay and headlight is the starter switch.
jag007 Apr 22, 2013 08:49 PM
Hello,
I need to re-word this,,
What I'm asking is are the two relays interchangeable?
Not if they are connected in the circuit.
I was searching here and read somewhere that you could swap in a headlight relay for the fuel cut-off relay.
If this is true, it would be a cheaper fix.
Regards,
Jag007
