Front Forks !! need more info
RE: Front Forks !! need more info
I lowered mine a total of an inch and a half in the front and raised the rear. Worked great, but if you are drag racing it alot you'll want to lower the front and rear and strap the front. You can drag it at the stock height but its just going to want to lift the front alittle.
Installed the f4i rear shock. Its a direct fit you just have to find a place to mount the reservior because the cable is shorter. This is the only picture I have of it with the rear raise and front lowered.
[Iimage]http://i143.photobucket.com/albums/r146/Dizyer/CBR600F3.jpg[/IMG]
TMAX
CBR1000F Wanted / Swap
11-18-2009 12:41 PM
