Free dyno day at Scotts Powersports was good
Took the bike for the free dyno day, my F3 got 84.6 HP an the misses bike made 88.1 HP. I read post that the 1996 f3 made 100 HP at the rear. Which we are off 12 to 16 hp, this could be a number of things but most likely a carb cleaning needs to get done.
My might be the carbon builded up on the valves and most likely the pistons.
Seaform is being used until I am able to pull the carbs and header to do a scrapping.
My guess is the best you'll see on the F3's is somewhere around 90-96HP.
Replace rings, valves, clean/synch/jet carbs, hi flow filter, repack exhaust can and do a 520 conversion with aluminum sprocket (just for the dyno, they suck for actual street use).
Maybe even throw in a cam job and you'd be bouncing under 100HP. nice numbers though for some daily driver F3's! Good work!
+1 on the SeaFoam.
+1 on the SeaFoam.
Whoever said 100hp at the rear wheel was either telling porkies or was using a very optimistic dyno. All the F3 dyno charts I have seen, where the bike is relatively stock maybe with an air filter and slipon, make around 88-89 HP at the rear wheel.
Could have been 100 at the crank. Thats the figures the manufacturers normally publish - especially back in the day.
ORIGINAL: apj
F3's are supposed to be 100-105 at the crank, 85 or so at the wheel. The guy who sold me my bike said he changed the heads (and added a slip-on) and it dyno'd at 95 at the wheel. Since he gave me the stock heads I'm inclined to believe him.
2011, cbr, chart, day, dino, dyno, f3, horsepower, power, powersports, scotts, scottspowersports, seafoam, sports, wwwscottspowersports
