Fork settings
Old Sep 12, 2010 | 07:26 PM
bikersam717's Avatar
Default Fork settings
I'm about 5'9" and weigh about 145lbs with gear. How should the screws on the top of the forks be adjusted? It seems the little dots on them are off, even when theyre screwed all the way in or out. Is there other adjustments I can make, and where are they located? The front end seems off to me... Don't know how to explain it.
Currently they are 2 full turns back from all the way in.
Old Sep 12, 2010 | 10:24 PM
OutlawF4's Avatar
Best place to find your stock settings are in an online manual for your specific bike. I have an F4 and stock setting is 1 and a half turns out. the preload for mine is 3 lines stock.And the setting on the bottom forks(compression damping) is 1 turn out. Im goin through the same thing on mine and will let u know if I find out anything important to add. Start with your stock settings, refine from there.
Old Sep 15, 2010 | 02:52 AM
pacemaker's Avatar
I'm pretty close to you're height & But weigh a (ahem, cough) tad more, my comfort settings are 3 Bars showing & Rebound set at half way. I've tooled around with different settings, but I find those just right for me, every ones different. Since owning two Guzzi's, every thing since is a plush & comfortable ride
Here are the factory settings:
Old Sep 15, 2010 | 10:50 AM
WiSH2oo0's Avatar
If I wait long enough I'll just print out a copy of that book of yours Pace
Moses
Old Sep 15, 2010 | 09:53 PM
pacemaker's Avatar
Moses
Lol, Just give me time..
Vinman911
Jun 12, 2018 10:35 AM
FlyWheel
Sep 18, 2012 07:49 PM
Incompatible
Sep 9, 2011 07:35 PM
driyac
Jul 11, 2010 02:40 AM
civicblade
Apr 23, 2009 08:24 AM
