Fork bushings
Old Apr 13, 2008 | 08:39 PM
sportracer07's Avatar
Default Fork bushings
I have a 1995 f3 and everytime I hit a bump or I hit the front brake quickly I hear a pop and you can feel it in the grips. How can I teel if this is the fork bushing or if it is steering stem bearings?
Old Apr 13, 2008 | 09:01 PM
SurfnSCal's Avatar
Default RE: Fork bushings
I would lean more towards steering head bearings. maybe there is excessive play, maybe they are getting worn. I woulld try to tighten the steering head bearings. As for the fork bushings? I'm not sure how to check for them other than when the forks are apart. They are teflon coated and have a dark grey coloring to them, when that coating wears you see the copper material more and more and you should replace them at that point. Also what i've seen is that your steering head bearings are good, and your fork bushings are good, but that top nut ontop of your triple clamps isn't as tight as it should be, and that allows play on the top triple causing what you describe. Give that a shot first, then adjust steering bearings, and then go to forks.
Old Apr 13, 2008 | 09:03 PM
Scrufdog's Avatar
sounds just like what my bike was doing when the steering stem bearings went out.
I just rebuilt my forks and there really isnt anything in there that could get 'caught' and pop.
dk275
Jul 10, 2011 12:16 PM
driyac
Jul 11, 2010 02:40 AM
civicblade
Apr 23, 2009 08:24 AM
WhiteHawk
Mar 17, 2009 10:17 AM
91taurisho
Apr 29, 2006 10:08 PM
