F3 lowering link
Old Oct 19, 2006 | 08:52 PM
PatsCBR's Avatar
Default F3 lowering link
Hello im a newbie here and to the CBR F3.. I just got a pretty great conditon 1998 CBR 600 F3 with 5,300 miles.. Im wanting to lower the bike with a dogbone.. My question is the billet dogbone with two holes is that a 3 inch drop? Also when dropping the rear 3inches how do people drop the front to match.
thanks
Patrick
Old Oct 19, 2006 | 11:56 PM
Triax's Avatar
Default RE: F3 lowering link
I believe that is a three inch drop in the rear. To lower the front you have to loosen the bolts on the triple tree (4 if i remember correctly) and just slide the forks up the triple tree. I wouldn't drop it more than and inch and a half in front otherwise it will bottom out. Why are you trying to lower the back so low? I'm 5 foot nothing and all I did was lower the front and inch and a half and it was perfect. I had to one foot it at lights but it never bothered me
Old Oct 20, 2006 | 02:49 AM
PatsCBR's Avatar
Thanks Triax
Im exactly 5 foot nothing and lights are my only concern and another rider get on.. I'm going to just lower the bike as much as I can to get it the most comfortable for me..
Old Oct 20, 2006 | 03:12 AM
bindelsf2's Avatar
yes that is the link that i have and its 1 or 3" drop.... but you cant drop your bike 3" the linkage wont let you because it hits on the shock itself..(there is a 3" hole on there because the dogbone is made for 6 different bikes).... and if you found a way to use the 3" the bike would be higher in the front because the trees that low wont clear the fender from rubbing on the tire.......
if you drop it the 1" you have to raise the trees 1 1/4" ....
heres some reading...(2nd time i have posted this link tonight.wierd) http://www.sportrider.com/tech/146_0210_lower/
Old Oct 20, 2006 | 03:27 AM
bindelsf2's Avatar
this bike was lowered 1" in the rear and 3" in the front????????...look at his fairing behind the front wheel, the front wheel clearance between the fender and how far the triple trees stick up..... dont get why it is set up like that...
[IMG]local://upfiles/7261/5F5EEDF25AE34017BFCB744643DD1325.jpg[/IMG]
Old Oct 20, 2006 | 05:10 PM
PatsCBR's Avatar
Thanks guys for the info
Looks like that guy in the pic was looking for the drag style look?
Old Dec 5, 2006 | 01:55 PM
PatsCBR's Avatar
UPDATE>>>>>>>
I installed the lowering link and lowered the rear 3 inches and the front 1.5. All I can say is its amazing the confidents I got!!!!!!! I feel there was no effect on handleing except the fact you cant lean the bike over as far as before.. Im not a huge knee dragger so im ok with that..I also think I might have to becareful with speed bumps but all is worth it for the new confidents I got!!!
Old Dec 5, 2006 | 05:22 PM
bindelsf2's Avatar
congrads!! i like mine also!
to everyone that wants to lower their bike do it and see if you like it and if not you can always reverse it....i was skeptical from everything i read but i did it anyways and i love it...
Old Dec 5, 2006 | 05:25 PM
PatsCBR's Avatar
ORIGINAL: bindelsf2
I was too but when your short you have to give alittle some where and i was willing to loose the hard lean angles for the great over all comfort...
Now on too more power........whooo hooo
Old Dec 6, 2006 | 12:55 PM
CajunCBR's Avatar
What did you guys do with the kick stand? Bend it??
