F3 Fork differences?
Hi Guys, I am looking for a set of F3 forks and need to know if there are any differences between 95-96 F3 forks and 97-98 F3 Forks. I have read somewhere that 95-96 just have compression damping adjustment where as 97-98 has compression and rebound damping adjustment. Can anyone confirm or deny this, thanks.
F2 94 forks has preload adjustments I guess. F3 forks has newer cartridges with load and damper adjustments. F3 forks are the same for all the years as I know.
I'm just talking about 95-98 F3 fork legs. I know the F2's were damper rod forks and I'm not interested in those.
Most have said the F3 cartridge forks with preload and compression damping adjustment are the same from 95-98, except "TRACKF3" who has said the 97-98 are very different internally from the 95-96 forks.
Can anyone clarify? Thanks for your help on this.
The largest difference that I have found in the 96/96 and 97/98 forks is a little ball bearing in that makes clicks when adjusting the flow rate on the dampener. Honda removed that feature in the 87/98 forks. I also know the springs are different... being the 97/98 are stiffer than the 95/96.
driyac
07-11-2010 02:40 AM
civicblade
04-23-2009 08:24 AM
