F3 to F4i Gauge Swap
#171
I must have something funny going on ive checked my wires 3 times now and there definately plugged in right according to whats given here... especially since it worked fine all last year but now i just blew a 10 amp fuse for my ignition put another in and it seems fine except my neutral lightis always on and still no tachometer...mph works but no rpms... im confused
#172
#173
#174
#175
#177
Ok, then I think you're good to go.
On a side note, here's a cool site that will hook you up with the 2 sets (male/female)
of 9-pin connectors to make it a plug and play/factory-like set-up.
OEM-Type Bullet & Spade Electrical Connectors for 1960's through 1970's Japanese Vehicles... Bridgestone, Datsun, Hodaka, Honda, Kawasaki, Landcruiser, Suzuki, Tohatsu, VW, & Yamaha
Hope it all works out, Ern
#178
#179
Hi ok just need to change the f4i clock miles to my clocks
I looked at scrufdog`s thing
with software i need but not getting any thing is the pink/green ?speed sensor pickup ?
on f4i gauges i have looked at the f4i wire diragram and there is 3 wires on the speed senor
P/G BLC/BR G/BROWN
So which wire is it
I can get it to work but just have to put one wire on P/G and more it up and down on the exhaust and it starts and stop but it works slow????????????????????????????????
P/G BLC/BR G/BROWN
So which wire is it
#180
P/G BLC/BR G/BROWN
So which wire is it
P/G BLC/BR G/BROWN
So which wire is it
To set mph-kph, do the same as before, only press and hold the top button.
as far as the rest of what you said. I do not understand. just do the swap as per the instructions. they are proven.
