F3 to F4i Gauge Swap
Old 05-10-2012, 09:16 AM
Will.Bass's Avatar
Originally Posted by impaladre
I did the gauge swap everything works except my speedometer, neutral light, trip log, and temp readout. The speedo stays at 0 while i'm riding and the trip stays at 0.0? do i need to wire the pink wire and the green wire together and then ground them out? Odometer read 50k, fi indicator works, blinker ind. works, tach goes all the way around and comes back as it should, clock stays the same. Just no speed reading, no neutral light, no trip log, and temp readout stays at --?
F3------------------------------------------F4i
Green/Blue -------------------------- Green/Blue
Pink/Green -------------------------- Pink/Green
Black/Brown ------------------------ Black/Brown
Brown ------------------------------ Brown/White
LtGreen/Red ----------------------- LtGreen/Red
Orange --------------------------------- Orange
Light Blue ---------------------------- Light Blue
Blue -------------------------------------- Blue
Blue/Red ------------------------------- Blue/Red
Green (one) -------------------------- Green (one)
Green/Black ------------------------- Green/Black
Yellow/Green------------------------ Yellow/Green
Yellow/Black------------------------- White/Blue
Solid Pink ----------------------------Green (two)
Brown/Black--------------------------- not used
White/Blue---------------------------- Not Used
Red/Green ------------------------- connect to battery
  #162
Old 05-18-2012, 06:35 PM
CaBeR6's Avatar
Originally Posted by jacked600
ya hey, no one answered is question... I also need to know the answer..... how does that work now that it is digital ? is there somethng else other then the cluster and the 900rr thermostat switch that I need to purchase ??
thanks
-Lee
I doubt it can be done with yours as need a F£ with speed sensor that works on gear box
If you put bike on center stand or rear paddock stand and put it gear and rev it up if speedo needle moves then it can be done if it dont move then conversion (mod) cant be done
  #163
Old 05-29-2012, 02:59 PM
wargamesuk's Avatar
Hi
Waitng to buy f4i gauge for my f3 1998
But need full info and what parts i need to do this looked on here but just in
Bits not full
Found one but pictures donot show so can anyone help me
Got my new fairing on now waiting to get my wheels back from the shop getting them power coating
So will put pictures up soon
REPSOL fairing
  #164
Old 05-30-2012, 11:07 PM
BPWilson_F3's Avatar
Originally Posted by wargamesuk
Hi
Bits not full
REPSOL fairing
Just the F4i gauges and what ever wiring method you choose. 900RR temp sensor is optional as the F3's fan and switching mech. are not controlled by the gauges, only the resulting temp is read and displayed (inaccurately). So if you don't mind it saying your at 250+ degree's and a red light you'll be fine.
  #165
Old 06-02-2012, 04:24 PM
tricksta1984's Avatar
ive lost my tach as well (rpms) which wire is this exactly cans omeone clue me in to narrow this down ive triple checked my wiring plus it worked fine last year
edit............ i believe i found it being the yellow with green on it nothing wrong with the wire not sure if its the guage or not
lol now i put it back together and its blowing my headlight fuse........grrrrrr
  #166
Old 06-02-2012, 05:55 PM
MadHattr059's Avatar
Here's the conversion chart as to how to hook up the F3 harness to the F4i guages...
F3 to F4i
Green/Blue---- Green/Blue
Pink/Green----Pink/Green
Black/Brown----Black/Brown
Brown----Brown/White
Light Green/Red----Light Green/Red
Orange----Orange
Light Blue----Light Blue
Blue----Blue
Blue/Red----Blue/Red
Green (one of them)----Green
Green/Black----Green/Black
Yellow/Green----Yellow/Green
Pink (solid pink) - ground this out (other green)
Brown/Black - fuel reserve sensor - not used
Red/Green - battery(+) - connect to battery
White/Blue - fi indicator - not used.
Yellow/Black----Green/White
This is where you have an option..
courtesy of iwanta900rr: .....I finally discovered how to use the 'FI' bulb as the kickstand indicator!!
To add, it is also functional in that if you put the kickstand down in gear, it stalls!
f3's yellow/black wire connects to f4i's white/blue wire AND NOT it's green/black wire.
Hope this helps, Ern
  #167
Old 06-03-2012, 02:29 PM
wargamesuk's Avatar
ok still can not find any f4i gauges
But did find these
CBR929 CBR 929 gauge
will this work?
on f3 1998
  #168
Old 06-04-2012, 08:07 AM
wargamesuk's Avatar
Ok found some for £200.oo is that about right price they say it of a f4 but look the same
Attached Thumbnails  F3 to F4i Gauge Swap-kgrhqr-lqe9hsfk-bubpqgow-mrq-60_12.jpg
  #169
Old 06-04-2012, 11:30 AM
Will.Bass's Avatar
those are f4i
f4 would look like this...
99-00 HONDA CBR600F4 SPEEDOMETER gauges tachometer cbr 600 F4 1999 2000 99 16k | eBay
  #170
Old 06-04-2012, 12:00 PM
wargamesuk's Avatar
ok will buy now thanks will.bass
Quick Reply: F3 to F4i Gauge Swap
