Engine Maintenance
WHo is getting tired of seeing my questions? Anyone? I really appreciate the help.
My new question: I have seen some stuff about cleaning the carbs, and checking valve clearances. My bike has 35K.....Is it time for all that?
For those who can't tell, I am basically attempting to restore this bike to as much glory as possible and keep her running good.
Thanks
Thanks
I would to be safe, the valves are every 16000, so you're at 35000, probably time for the second one cause people don't tend to send things in if there is nothing noticeably wrong. The carbs I would synch after doing the valve adjustment since that's every 8000, it should smooth up the idle. Past that if you're really ambitious look into drop tuning it.
I'm in agreement with dyracuse. Time for valves and carb cleaning. I just need to take that advice too. I got my red F3 a couple of years ago with 10K and it's got 35K on it now. Haven't done valves or carbs on it yet. My bike runs so good right now I don't want to tip the apple cart so to speak. We're planning on a N. East coast trip sometime in latter part of July, hit DC and NY, NY if possible. I'm thinking I should do it before then.
Holla when ya hit the area
TBH I think I upped to the F4i simply to avoid checking the valves on the F3. Now I got another 13k before facing that
DC & NY? Ya know PA is in between the 2
As far as carb cleaning..... I probably wouldn't touch them if the bike is running good. Why tear them apart if you don't have to? Run some seafoam through the tank.
On the valves, yeah... I'd probably check them out. I check valves on just about every vehicle I buy. Most don't, tho.
It will not be as effective as actually pulling and cleaning the carbs by hand. But it can help with minor issues. It's not to be used with every tank either.
It can also be used as a fuel stabilizer for storage
If you dive into the carbs, most likely you're going to find that o-rings need to be replaced. There are several o-rings between the carbs and inside the carbs that just get old and need to be replaced. In addition, you'll probably also find that the carb insulators will need to be replaced. If you do the carbs, budget for something in the area of $250 for parts. If you're hard pressed for cash, you can disassemble and reuse the old o-rings if they aren't cracked or damaged.
When assembling the carbs, you'll need to sync them. The motion pro carb sync tool a good for this or just search around for making your own vacuum gauges.
