Dyna 2000 CDI Function?
Old May 21, 2014 | 02:18 PM
SmokinJoes's Avatar
Default Dyna 2000 CDI Function?
Link.
I have a rudimentary understanding of what this is. Is this install done exclusive of installing an ignition advancer? I already have a +2 pulse rotor installed, but it sounds like this Dyna CDI upgrade does the same thing?
Old May 27, 2014 | 08:28 PM
gpfan1's Avatar
With a laptop you can advance the timing, reprofile the advance curve, add in retard for high rpm running. You wouldn't need a +2 rotor with this.
Old May 28, 2014 | 03:38 AM
jackojeff's Avatar
I have an ignitech re-programmable CDI unit and it allows for better advance curve through the range once set up correctly mine pulls like a boss from 6k
far better than a normal ignition advancer as you gain through the whole range rather than gaining mid range for a drop in high range power or the otherway around
it also helps your air to fuel ratio be as flat as possible
Old May 29, 2014 | 10:22 PM
SmokinJoes's Avatar
And these benefits hold true for carbureted engines, including the ones in the F3's?
What happens if you run one with an +2 ignition advancer already installed?
mpbond
Jun 2, 2012 06:03 PM
OneNice900
Jun 28, 2010 04:31 AM
l0st1
Oct 5, 2009 01:20 PM
beater 900rr
Feb 4, 2005 11:11 AM
