Dyna 2000 CDI Function?
I have an ignitech re-programmable CDI unit and it allows for better advance curve through the range once set up correctly mine pulls like a boss from 6k
far better than a normal ignition advancer as you gain through the whole range rather than gaining mid range for a drop in high range power or the otherway around
it also helps your air to fuel ratio be as flat as possible
