differences in oil
whats the difference between 2 cycle motor oil and 4 stroke motor oil and what are the consequences of adding 2 cycle oil in a 4 stroke? stupid question but just curious someon throw some knowledge at me!!
I can give an opinion, but it's not based on anything other than conjecture. 2 cycle oil is designed to be mixed directly with gasoline. 4 cycle is not. I would think that the additive packages would be different based on the environment that they are designed to work in. 2 cycle oil tends to be thinner than 4 cycle oil, so if it were put into a 4 cycle engine, it may not provide the protection that it needs. I don't have anything to support any of these statements though
Thats what I was thinking just wasnt sure. I was curious cuz a buddy of mine just got a 2001 R6 and he mentioned that he changed the oil but when i was in his garage i noticed he bought amsoil synthetic 2 cycle oil! I just thought to myself.... thats not good!! but thanx for the response
Sooo... I had this big long explanative reply and the internet crapped out and it didn't post it. So now I'm just gonnna summarize it.
In my 15 years of working with 4 and 2 stroke motors, this is what I've gathered.
2 strokes are "inefficient" with oil because they burn it. Because of this, you want almost no by-product when it burns. On some 2 cycle oil you will see the word "ashless". If you burned 4 cycle oil in your 2 cycle motor, it would gum up the rings, valves, exhaust, etc and eventually destroy your motor. Because it's meant to be burned, it is kind of a "one time use" oil. I believe the thermal breakdown and the protection factor is significantly lowered after 1 cycle through the engine.
If you run 2 cycle oil in your 4 cycle motor, it will be "fine" for a little while. Once it starts to breakdown though, you will lose protection and you'll F your motor. Drain it ASAP and he should be fine in that category. This being said, I have NO IDEA what 2 cycle oil would do to a wet clutch. That's what I'd be worried about the most.
