Did the GSXR R/R Conversion...
Old Jun 20, 2008 | 05:42 PM
Adionik's Avatar
Default Did the GSXR R/R Conversion...
WOw, bike seems to start up a LOT easier and idles better. Is this normal? I picked up an 05 gsxr rr plug and threw it on a 96 F3.
I haven't had the chance to just let it sit and idle...but the old RR would make the bike die after idling for 10/15 minutes
Old Jun 20, 2008 | 07:55 PM
bullit_70's Avatar
Default RE: Did the GSXR R/R Conversion...
sorry if this is a dum question but what is the GSXR R/R converson?
Old Jun 20, 2008 | 10:02 PM
jalen11598's Avatar
You can use a Suzuki GSX-R regulator rectifier on our bikes, with a little modification to the wiring and mounting. Our R/R has a tendacy to burn out pretty quick. The GSX-R's are larger and handles heat a whole lot better. And for you GSX-R riders who are probably reading this, THAT WILL BE THE LAST COMPLEMENT YOU WILL EVER HEAR FROM ME![:-] HONDA 4-LIFE!!!
Old Jun 20, 2008 | 11:48 PM
bullit_70's Avatar
ok i am going to pick your brain but what is the regulator rectifier? and what does it do?
Old Jun 21, 2008 | 12:02 AM
jalen11598's Avatar
On the right side of your bike (when your sitting on it) if you remove the right tail piece you will see two black square shaped things bolted onto your frame. The largest one is CDI (computer brain) the other one is your R/R. Don't touch it after you've been riding for awhile because it gets red hot! It controls the amount of voltage your bike generates when your riding it. When that thing goes out, your bike will act like it'son some serious drugs! Your battery will go dead, your gauges will start doing some funny things, the bike will act like it's running out of gas! They sell a heavy duty one that a whole lot better than the stock. I have one on my bike. But even the heavy duty ones can go bad. If you search this forum you will find that alot of folks has switched over to the GSX-R one just for that reason. Just pray that your not on a long ride when that thing goes out. I was about 30 min from home when mine went out, but I made it home. It wasn't pretty though, sweating bullets all the way!
Old Jun 21, 2008 | 12:47 AM
bullit_70's Avatar
oooo ok i get what you are saying. ok now sence you did this you said that you got one off a 05 GSXR however you said that you had to do some mods. what is all involved in doing this and what mods do you have to do?
Old Jun 21, 2008 | 12:58 PM
Sproutf3's Avatar
Registered Users
when my r/r went out, i jumped my bike and it would run if i kept the idle above 2500 i made it home like that.[:'(]
Old Jun 21, 2008 | 06:25 PM
Adionik's Avatar
NVM it's still running like **** and dying. I'm guessing because I put too much seafoam and not enough gas in the tank and killed it trying to crank it over and over again?
Either way I filled it up with 93 so we'll see what happens. I think my spark plug wires are shot. Anywhere to pick up a set cheap? Prefferably new. I wouldnt' care if they're aftermarket.
Old Jun 21, 2008 | 08:38 PM
willduce's Avatar
that sucks man....good luck
Old Jun 21, 2008 | 08:57 PM
Adionik's Avatar
Bike still won't start...kinda cranks and backfires and smokes so i'm on the path to fixing it. I will just run no more seafoam after this hahahah
