Dead battery. HELP
Hi guys,
First a little history. Riding the bike, get home, try to start the next day. Flat battery. Buy a new battery, lasts for three days then flat again. Call the local bike shop and he says replace the voltage regulator/rectifier. Charge the new battery replace the rectifier and ride around for a while. The thing starts a couple of times after riding around. Next day (today)dead again!!!!! What the hell could be wrong. Stator maybe? Any help appreciated. |
RE: Dead battery. HELP
same thing happened to my friend and after he replaced stator it was fine
try your voltage regulator it could be shot
what is the stator? How does it work? How does it work hand in hand with the regulator rectifier?
________ Renatta live |
ORIGINAL: netdevil71 Charge the new battery replace the rectifier and ride around for a while. ORIGINAL: pointman try your voltage regulator it could be shot ORIGINAL: F4iMane what is the stator? How does it work? How does it work hand in hand with the regulator rectifier? Original poster...check the stator...that would be the next bet, also are there any blown fuses, loose or shorted wires? Check the ground near the R/R and the stator connections(A service manual helps...its in the general tech forums under "post manual sites here") |
