D shaped tool. Why!!!
Old Mar 16, 2011 | 09:50 PM
Mrmanr's Avatar
Default D shaped tool. Why!!!
Can anyone tell me how to make a homemade tool to remove pilot jet! Or any tricks would be great! And when i get all jets out should i be able to blow compressed air through where i removed them. Thanks for any help!!
Old Mar 16, 2011 | 10:02 PM
89cb1's Avatar
Ya i just rebuilt mine. I just took a broken screwdriver and grinded down the end till it fit. But it worked fine taking them out but started to strip themon the way in. So I ended up having to get new ones from Honda, but the good thing is they redesined them so the head is now a phillips. And yes you can clean inside, thats the proper way to clean the carbs.
Old Mar 16, 2011 | 11:18 PM
kerosene's Avatar
I bought the stupid 90degree tool from motionpro and it's too small!
Old Mar 16, 2011 | 11:20 PM
Michaud85's Avatar
i just used a dremel to cut a slice in the D shape so i could just use a flat head. works perfect was free and didnt have to wait for a stupid part that doesnt work to come in the mail.
Old Mar 17, 2011 | 06:31 AM
Mrmanr's Avatar
Ill try that then. Do i cut through the carbs itself too? Becuase screw is inbedded in. Just want to know before i cut. Thanks guys!!
Old Mar 17, 2011 | 07:02 AM
pittsm's Avatar
^^^ yup
Old Mar 18, 2011 | 05:42 PM
Mrmanr's Avatar
ok i cleaned carbs cleaned every jet, spayed cleaner through every known hole,and everything lookED GOOD.no clogs except one idle jet. even did the dremel trick to remove pilots. bike still wont start! got spark, what else could kkeep it from starting . should it start even if pilots were not adjusted back i did 2 1/8 turns out please give me some advise thanks
Old Mar 18, 2011 | 05:58 PM
Dissevered's Avatar
2 turns out should get you started. Did you check spark on all cylinders? Did you make sure to put the plugs back in the right order? Choke working? Are your float bowls filling up?
Old Mar 18, 2011 | 07:35 PM
Mrmanr's Avatar
yes i checked spark on all 4 even replaced them, gas is fill in bowls i guess im going to check timing on cams.
Old Mar 18, 2011 | 11:09 PM
Michaud85's Avatar
dude try some seafoam. make sure your killswitch is turned to run. make sure ur fuel pump is working. and make sure ur giving it extra extra choke when ur rying to start some times i have to push really hard on my choke to get my bike to fire up but she does everytime.
i know youll get her running just dont give up bro
