crank case repair
crank case repair
My room mate knocked over my bike which was sitting behind his car in our garage. the right crank case was beat up a bit. the lower bolt was pushed a bit and cracked the bottom of the casing. it's leaking a bit of oil now. is this a fixable problem, or will i have to replace the casing?
RE: crank case repair
If you have time,I know a guy who can weld the case for you,but you'll have to tear the motor down and send the wounded part to him.
If not,you'll have to replace the motor or get a pair of good cases.The cases must be replaced in pairs,due to how they are cut.You can't use a lower from one and an upper from another.
Your roomate owes you big-time.Sorry to hear this dude.
