Cracked engine casing
Old Apr 19, 2009 | 04:43 AM
whynot0's Avatar
Default Cracked engine casing
Hi everyone,
I have been trying to track down the source of my oil leak for the last few days, it seemed to be coming from one of the mounting bolts on the alternator cover but i just took it off again and found what i think the problem is.
See attached pic.
Is this as bad as i think it is?
can anyone recommend a workshop in the south east of england (surrey preferably) that might be able to help me out?
Thanks
Old Apr 19, 2009 | 06:06 AM
jalen11598's Avatar
I'm no expert on this but, that crack looks so small that it looks like you could get away with just putting some J.B. Weld on it. I know the motor gets really hot, but for something that looks so small, I think I would at least try it once. Sorry to hear about that, good luck.
Old Apr 19, 2009 | 06:36 AM
willduce's Avatar
yeah i agree, at least try jb weld first
Old Apr 19, 2009 | 07:03 AM
whynot0's Avatar
hmm,havn't heard of that over here ... i wonder if theres a local equivalent?
Old Apr 19, 2009 | 08:30 AM
jalen11598's Avatar
Not sure what you may have over there in the form of a hardware store, which is what we call it here in the states or any kind of home improvment store. JB Weld is the name of the product. It's like a liquid weld or super glue for metal/steel thats very strong. If you can't find anything over there like that, let me know and I'll see about trying to get some out there to you.
Old Apr 19, 2009 | 08:47 AM
Adamavage's Avatar
I had the same problem after I rebuilt the engine.(wasn't going to re-do it again lol) I used so JB weld worked great let us know I'm willing to send some out as well. Good luck
Old Apr 19, 2009 | 08:48 AM
whynot0's Avatar
ok found some here, thanks will give it a try.
Old Apr 19, 2009 | 09:39 AM
JB Weld needs about 24 hours to fully cure. It's important that the area that you're applying it to is clean and free from oil. Use something like carburetor cleaner on the area (be careful not to get it places it shouldn't). It's very viscus and will get down into the crack and help get the oil out. The carburetor cleaner drys rapidly and doesn't leave a residue. After its dry, you can then apply the JB Weld. The JB Weld is kind of thick like warm peanut butter. But during the curing time it will have a tendency to flow. Try to get the motorcycle in a position that's not going to have the JB Weld wanting to flow away from the area you're trying to patch. Also don't let it dry against that allen head bolt or you won't be getting that one out anytime soon. Good luck and keep us posted.
Old Apr 22, 2009 | 01:32 PM
whynot0's Avatar
Ok ... all done.
seems to have worked for the moment.
Stil a small amount of oil in the area, but a lot better than it was.
Thanks for the help
Old Apr 22, 2009 | 02:07 PM
jalen11598's Avatar
Your welcome, no problem. Glad to hear your back on the road.
