Cluster swap from 96 f3 to F4
I found burnt wires at the connector from alternator to i believe regulator. I replaced connector but it did not help speedo problem. My speedo start at 15 mph when switch is on. It will very slowly climb until it eventually reaches max speed even if bike is just setting as long as switch is on. Wish it were something as simple as a burnt or loose wire. I also found the the wires going to my headlights had been taped together and the tape had came off so I butt spliced them but that has been the only wiring issues I have found so far...any help is GREATLY appreciated!!!
oldschoolCBR
03-08-2007 05:50 PM
