Choke seems to do nothing
Just bought a used F3 its running real good once it's warm, startup is a little boggy
I've noticed when I pull choke down it does nothing, usually i have to start it 5-6 times till it stays on very puttery , normally here you'd pull the choke down and it would rev up to warm up but in this case the choke doesnt seem to do anything
Is there something I can adjust ? Anyone seen something like this before ?
I increased my idle a bit so its sitting at about 1700 to make warmup a little easier
choke not working
hi
i have a cbr600f3, 97, it may just be the choke cable needs tightening. on mine i thought the same thing but after around halfway the cable slack is taken up and resistance is felt.......this is the true choke kicking in.
looks like the tank n air filters have to come off to access it so maybe this is why its overlooked!?
regards
stuart
regards
stuart
The little tab that pulls the choke was OUT when followed the cable
I just had to snap it back into place
I posted up a pick of what it looks like , you have to unbolt the tank, then open the air box, remove air filter, and remove another part of the airbox to get to it
Was not too bad, I had somone hold the Tank so I didnt take it all the way off
