choke on 98 f3
for some reason when i ride in traffic of stop and go my choke has to be all the way open or the bike will cut off. if i am on the highway with constant throttle its fine when its a little over half open like it should be i was told .but if i stop or slow down to much with it like that, the bike cuts off. what could be the problem i was thinking something may be wrong with my idle control that little swivel thingamajig[&:]
you shouldn't really be riding with the choke open at all - only use it to get to operating temperature. Fire the bike up and leave the choke open on full until temp needle goes above the line by the 'c'. then close the choke and see what the revs are at. it might be that the tick over control (below where your left leg will be - near the fuel reserve dial) is closed - twist it to open it up; this should increase/decrease the revs during tickover.
Really the ideal tick over will be 12-14k (mine's a 96/97 FT and about 14k is right). obviously this will increase as the engine warms up further, so may need changing when you are out and about.
if this doesn't work it could the idle itself or something more technical that i don't understand!
anyway, key things are making sure the tickover is at the right amount and that the choke isn't ideal for actually riding. always make sure you give the bike time to warm up.
hope i have been of help mate!
when i boight my F3 the guy who had it before me rode it up from santa rosa and he said that there was a problem with the carbs that they needed to be re syncd. well when he was riding it around for me the 1st night i looked @ it he was riding with the choke open like you described. i changed the idle control when i got around the corner then put the choke back to its normal position and the bike ran fine. im guessing because of the elevation difference thats why the guy had it adj the way he did but either way after i adjusted the idle the bike ran fine
ORIGINAL: havoc_on_2_wheels
ORIGINAL: connor
Yeah i have the same problem can anyone help?
ORIGINAL: paddygrant
I don't think it's healthy to leave the choke open until the bike is fully warmed up. I think it was either in the honda owner's manual or clymer manual or both that I read you should only have it open for a couple minutes at most then close it..if the idle is still too choppy for your liking at that point open the throttle a little bit. Then just let the bike sit until its above the C mark. I know one thing that can happen if you leave your choke open longer than that often enough itll discolour your perty exhaust.
