charging system fault finding help
Old Aug 30, 2010 | 01:00 PM
dcaldwell's Avatar
Default charging system fault finding help
I may just be reading into this to much but I'm going through the fault finding chart for my 96, and I'm not sure exactly what they mean when they say "Connect one of the multimeter-leads up to one of the three yellow wires (stator). Connect the other multimeter lead up to the engine case. Check the reading on the meter."
what/where do i connect this to the engine case?
sorry if this seems juvanile for some of you but electrical stuff is not something i understand well
thanks,
oh, here is the link if you want to look at the flow chart (my question is on page 4, second step from the bottom)
https://docs.google.com/viewer?url=h...ng-diagram.pdf
Old Aug 31, 2010 | 02:28 PM
espelade's Avatar
They are just using the engine case as a ground point. You could also use the neg battery terminal or frame for this test. it is just to test that the R/R is functioning properly by regulating the voltage.
ljc2004uk
Dec 4, 2013 05:36 AM
816_wallace
Sep 10, 2011 10:48 AM
Flogger
Jan 20, 2008 10:39 PM
lococbrf2
Oct 14, 2007 11:38 PM
jb
Aug 18, 2007 08:14 AM
