Changing tires
RE: Changing tires
My thoughts are:
Front tires:
1. have two buddies left the front forks while you use car jacks to hold the position in.
2. make a make-shift ramp, and insert the jacks in ( with a buddies help)
Back tires:
1. Have a buddie hold the front with brake while you jack up the bike from the swing arm
2. insert in the jacks (both sides)
Just an idea...
Front tires:
Back tires:
Just an idea...
RE: Changing tires
come along from the ceiling and tie downs work. I have a small car jack and I used that before I bought a stand. I put the jack somewhere under the shock on the frame somewhere. (I had someone holding the bike so it didnt fall just in case, then i put a pair of jack stands under the swingarm. Very tight.
