Changing Handle grips?
Old Apr 29, 2009 | 09:49 AM
jpanside@gmail.com's Avatar
Default Changing Handle grips?
has anyone changed the handle grips on their bikes? I just bought some sweet new gel grips and I tried to take the old ones off but it seems like they are glued on. This means I need grip glue to put the new ones on huh? Darn!
anyone know an easy way to do this?
thanks!
Old Apr 29, 2009 | 10:27 AM
irocthestreet's Avatar
i changed mine like a week ago. all i did was take a razor and slice the old one off. then cleaned the bar with contact cleaner(you can get that pretty much anywhere) then put some contact cleaner in the grip and pushed it on. some parts will be rough when pushing but make sure not to twist it.
Old Apr 29, 2009 | 10:28 AM
o and you have to let it sit afterwards for 2 hours
Old Apr 29, 2009 | 10:34 AM
ldv12's Avatar
Yeah they are glued on and ull need grip glue when u put em back on. To get off, take off the bar ends if you have em and then ull have to slide somethin small around the grove where grip meets the bar to kinda get the to start coming off. You can even spray window cleaner, i read on another post,( i actually used a lil wd40) to loosen up the grip n it slid right off for mine after a few twists. I actually saw a guy on youtube just slice the grips in half n then peel them off. Thatll prolly work too.
Old Apr 29, 2009 | 01:02 PM
gangofhoes's Avatar
I swiched mine a wile ago but i used the same method as rocth i just cut them off and cleaned them up with some gu gone worked really well and that dont slid around.
Old Apr 29, 2009 | 03:25 PM
willduce's Avatar
just cut the old ones off, but when putting new on heres a tip. put some glue on the bars and get a blow gun and blow air between the grips and bars while sliding on. it will balloon up the rubber grips and they will slide right on
Old Apr 29, 2009 | 05:18 PM
haha thanks guys all real good tips!
Would gorilla glue be okay as grip glue? or would I have to buy a specific glue?
Do i really need glue? Or will they just stick on and stay put?
Old Apr 29, 2009 | 05:21 PM
willduce's Avatar
you should use a glue, id imagine gorilla would work...cant be any worse than no glue at all
Old Apr 29, 2009 | 09:41 PM
i didnt use any glue at all and mine are fine
Old Apr 30, 2009 | 01:53 AM
thanks guys! now help me with my windscreen and nose fairing problem =P I cant get it off!
